I'm still working on this 1974 Evenrude 40 hp Norseman # 40454S, It seems the shaft won't come out with the lower unit. I noticed the impeller was new, I also noticed a slot cut or filed into the impeller housing. I believe the previous owner couldn;t remove the shaft either. So he lined the cut out and impeller keyway up and attemped to slide the L/U up while turning the flywheel. He must have knoced the key loose, I found it inside the housing with damage to the housing top. I have had the motor upside down for days spraying PB Blaster on the shaft everyday and hitting the shaft with a nylon hammer No Luck. Is there a pin or locking device on this motor? all the other OMC motors I've worked on before slide off with the driveshaft in the L/U. Thanks Mars
