Well there seems to be just problem after problem with my motor at the moment. I tried removing the driveshaft (whole lower case) but it won't budge. I've heard that it's quite common that the driveshaft gets rusted in engine. <br /><br />Now I've tried a solution to break up the rust by squirting it down along the driveshaft, and it's moved a little.<br /><br />Are there any other sure fire, more effective methods of extraction?? I really need to check the impeller as the 'tell tale' has become a dribble.
