PlayD0h
- Apr 23, 2009
- 326
so I have 1 coat of paint on, using the rusto topside and it didn’t atomize all that great. I used rusto’s directions and mixed 15% xylene, yet there are a few other ratios reccomended which call for more acetone/xylene. I just read that acetone is recommended for lower temps, xylene for higher, so I’ll use acetone next time.
My gun sprayed primer good with the same setup, 1.4 tip hvlp gravity fed. My only theory is that the paint was at 55-59°, and that bringing the can in the house to warm up before spraying might resolve the problem.
I really want to follow rusto’s ratios, yet I wonder why a lot of people use other ratios? I’ve seen people say a 1:1 works good, but I can’t imagine that gets much paint on.
I was planning on using valspar hardener, yet now I’m leary, since rusto apparently doesn’t recommend it. From what I’ve learned is that hardener chemically cures the paint, and the only real ‘benefit’ is a quicker cure time which somehow makes the finish more shiny. If I have time to wait, is it better to skip the hardener? Does it actually make the paint more durable?
my plan is to paint and let it sit for 2 weeks or so before flipping it upright and trailering it. At 55° average is more time better?
