wild.coast
- Sep 17, 2022
- 20
Trying to get a new to me motor up to snuff with maintenance. Got a sense that the previous owner might not have been doing much in the way of post-use water flushes so wanted to get the cooling system cleaned up.
Got some Rydlyme and set up a flush cycle using a sump pump. 1:1 mix of water and Rydlyme. Solution started foaming, which apparently should be expected. However, after 2hrs it was STILL foaming...
At 2.5hrs... still foaming:
Apparently, according to Rydlyme instructions you know the lyme and contaminantes are cleaned out when the foaming stops. However, in my case after 2.5hrs it was still foaming lots so I did just turn it off.
I also noticed after the bucket sat for a bit that the solution turned red/pink!
Curious about others' experience with Rydlyme, is what I'm seeing expected? Any ideas about the red color??
Max
Max
