Sacraficial Annode ..zinc...magnesium...aluminum
crazy charlie
The annode that mounts under the drive bell housing typicall called claw annode on a mercruiser is made of zinc.I go through one every 2 years on each drive,Bought a few online made by a company "Martyr" .I ordered zinc for my 1988 alpha ones however they are much lighter in weight than zinc.They must be either aluminum or magnesium.The least noble metal is sacraficed to spare the bell housing.Anyone know if aluminum or magnesium will work the same?? Better??? worse?? Anyone familiar with "nobleness"?? Im running in salt water which is a factor.Charlie
Zinc is more sacrificial than aluminum and magnesium
I prefer to replace the zinc more often than risking something else disappearing
wrench 3
ZincAluminumMagnesium
For use in salt waterFor use in salt, brackish and fresh waterONLY for use in fresh water
Not recommended for use in fresh waterProven to last longer than zinc due to increased capacityNot recommended for use in salt or brackish water.
Baylinerchuck
Not to hi-jack, but I'm really curious about fresh water sacrificial metals. I was under the impression this was only a salt water thing to worry about. Should a fresh water boat be concerned with anodes too? Learning as I go.
Never mind. Read dingbats article. Extremely informative. Thank you dingbat
wrench 3
Here is some of the rest of the article.
Understanding Galvanic Corrosion:
When two dissimilar metals in contact are placed in an electrolyte (an electrically conductive substance, ie seawater or even fresh lake water), electrons begin to flow (just like the plates of a battery), resulting in an electrical current. This action kickstarts Galvanic Corrosion. The metal that loses electrons is called the "anode" and the metal attracting the electrons is called the "cathode". Galvanic corrosion will eventually lead to the complete and utter disintegration of the anode!
Which metal will become the anode, and which will be the cathode?
As you can imagine, in a potential galvanic corrosion situation, the metal that is highly active (ie suspectible to corrosion) will become the anode, while the noble (corrosion resistant) metal becomes the cathode.
Obviously, if you have good quality boat parts, they will be made of corrosion resistant metals (ie, stainless steel) or if they aren't corrosion resistant, they'll be at least coated with a good layer of paint! But as we have learned, virtually all metals will eventually corrode, and paint does get damaged - causing the metal underneath to become vulnerable.
Using Galvanic Corrosion to fight Electrochemical Corrosion!
As mentioned earlier, when your boat's metal is placed underwater, chemical reactions begin to occur between your metal and oxygen dissolved in the water. Even if your metal is corrosion resistant, due to Electrochemical Corrosion, the "rusting process" will eventually happen!
However, by placing a highly active metal nearby your less-active metals, this will cause galvanic corrosion to occur in the more active metal. This sacrificial active metal anode "rusts" preferentially, instead of your precious boat bits (now called the cathode).
In other words, the "rusting process" likes to oxidize whatever metal it can get its hands on. The sacrificial anode is more easily oxidized than the metal that it is protecting.
crazy charlie
thanks guys.guess I have to figure out if my new annodes are aluminum or magnesium.Im thinking alum bacause of the bright metal color.
when I designed heat exchangers, we used zinc to protect the heat exchanger regardless if the water was salt or brackish.
yes, for an anode, aluminum will last longer than zinc, however is the aluminum anode actually the part disapearing, or are parts of your drive as well? how do the electrons know that they should be stripping the anode and not your drive.
I prefer to have a more sacrificial anode and change it more often than one of nearly the same material that my drive is made of. part of my maintenance is changing the zincs when they start getting bad.
crazy charlie
Mercruiser was having BIGTIME issues with bravo drives in the late 90s early 2000s.The drives and bellhousings were getting eaten up along with the zincs.Their fix was to make sure aluminum annodes were being used .At that time everyone used zinc exclusively not being aware of the aluminum annodes.Had a couple of friends with those exact issues.Charlie
