Safe way to cut a fiberglass hull for speakers
Bayliner175xt
Hi just wondering if anyone has used a jigsaw with a fine blade to cut out holes for a pair of 6" speakers in the front of a bow-rider (Fiberglass).
Pre drill then jigsaw !!!
Your thoughts people.
thanks :cool:
dsiekman
Re: Safe way to cut a fiberglass hull for speakers
Sounds like it would work. Might try a dremel, too. Or a Rotozip...
I'd say cut the hole small and come back with a file or dremel to clean it up. You'll be surprised how quickly a file will take down fiberglass!
kenmyfam
Start small and work gently toward the size you need.
Mr_Shamrock
They sell hole saws that give a clean perfect circle.
a70eliminator
Jigsaw with composite blade works great, I drill my starter hole so it lands right on the circumference, then cut slowly and carefully right dead on my mark.
Make sure to do a dry run, just go through the motions without a blade just to see that you have clearance all around.
Oh one other important thing, protect your skin or you will itch like crazy.
Mr_Shamrock
If your going to use a jig saw make sure you either tape up the bottom (foot) of the saw or tape way around your cut out area or both. The jig saw foot will scratch your fiberglass.
scca vette
I used a Jig Saw with a pretty agressive bit and had no problems. I do suggest using a little smaller blade than I sed however it worked fine for me. Just drill a hole to start and follow the line you traced. I just installed the 2 6x9 speakers and lights in my engine cover and had 0 issue. I do agree with the comment that it will scratch or leave some marks on the foberglass. This was no big deal for me do to I was going to wetsand and buff the piece after all the holes were cut anyways.
Here is a photo of mine installed in the engine cover.
RoryDominick
I used a dremel tool, it worked great. It has a blade that looks like a drill bit. Just wear a dust mask.
Chris1956
Cutting and grinding fiberglass is easy. Sanding is easy as well. Use any king of tool that cuts wood. A finer blade is better for finish work. Jigsaw, sawzall, skilsaw all work fine.
The itching effect is overrated. However, if you get a lot of the FG powder on you take a shower and use a washcloth on arms, neck and legs if necessary.
H20Rat
I've cut A LOT of holes in fiberglass, as well as made a fair number of my own speaker boxes out of fiberglass. (used to compete in car audio) Anyway, a rotozip with a fiberglass cutting bit is by far the best/easiest/most pain free way of doing it. Doesn't even have to be a true rotozip, I use a cheap harbor freight clone.
Jigsaws are ok, unless you are cutting into an area that might have wood backing behind it. They will tend to scratch the gelcoat though if you don't protect it, as well as break it on the cut line.
seabob4
These work great, get a cheap one from HF...
ajgraz
Dunno what all you got in the way of tools, but here's what I'd do with what I have if faced with that task:
Make a wooden round on a router table (or with a hole saw if have one large enough), small hole in middle, radius equal to radius of hole minus radius of dremel 565 multiprpose cutting attachment:
http://www.tylertool.com/drem565mulcu.html
tylertool_2113_223430126
Bolt the round through the center, centered on the fiberglass to be cut out. Drill a starter hole, then cut the round out with the dremel and the cutting bit, using the wood round as a template, making at least 3 or 4 total passes.
a 5" hole saw and a corded power drill will give you a perfect fit, no exceptions. Because it has a drill bit through the center it won't wander and at $4.99 at harbor freight, it's the cheapest insurance you'll ever buy. I used it to install all of the speakers off my dual stereo from west marine.
Just remember, measure twice and make sure you know exactly where you want them.
