Re: Safest way to hook up electronics
You said INTERIOR lights in a prior post -- now it is SPOTLIGHTS so which is it? If you have some interior reading lights that you are calling spot lights, then it might make sense to have those wired directly to the battery. You then disable everything else by turning off the battery switch but you can still have interior lights. Sort of a dumb way to wire things since you can then leave the boat with a light on. See what I mean about how many wrong ways there are to do things. You also said you wanted to re-wire the boat. Why? This task is often undertaken by a novice only to end up with more problems than you had in the first place. Why not just correct what doesn't work and clean up what you think is just sloppy work.
