Re: Salt-Away Flush
Yes, I use it.
It seems to work.
I flush the engine first with fresh water for about 10-15 minutes, then run the salt away through and leave it in the engine until next time I go out. It seems to dissolve the salt. Since using it I have had flakes of dried salt block the pee tube. Just had to pull off the nozzle and clean the salt out.
The thermostats look better and last longer as well. I check the thermostats once a year and have been able re-use them now for three years. They still look new.
