- Jul 18, 2011
- 18,285
My cooling system issues of last year schooled me a bit on heat exchangers and calcium (salt) build-up inside them.
I have twin 7.4 MPI engines with aftermarket FULL closed cooling systems. . . Bravo 3 outdrives. . . Ocean boating.
This year as part of my end-of-season maintenance I figured that, as a preventative measure, I would run some Salt-Away through the sea water side of the cooling systems. So, after Googling a while and reading the Salt-Away product information, I made up a couple of 3 gallon batches of 15% Salt-Away and sucked it into the cooling system (i.e. oil coolers, heat exchanger and exhaust elbows) and let it sit for a few hours. I figured that 3 gallons was about enough to fill the sea water side of the cooling systems, as the Salt-Away (blue in color) was just starting to show in the exhaust water.
Then, after waiting a few hours, I ran regular water through the system for about 5 minutes to flush out the Salt-Away.
I was initially considering using CLR as a less expensive approach, but the CLR product information said not to use it on brass/aluminum/copper
I'm not sure what it would do to those metals, but by contrast, the Salt-Away is recommended for use with all metals and particularly closed cooling systems/heat exchangers.
I'm not sure if other folks do a similar thing with their I/O engine and closed cooling systems, or even an open cooling system I/O. Most of the searching that I found was folks flushing their outboards with the stuff.
Thoughts/comments?
Thoughts/comments?
