Salt Water Trolling Motor
golver
I have a 21'Wellcraft V20 that will be used mostly in salt water. I do not know in what insistence I would need a trolling motor, but assume since I will be primarily fishing from this boat, I will need one. <br /><br />Does anyone have any recommendations? The cheaper the better as I don’t know how often I will really use it. <br />What pound thrust should I look at?<br /><br />Lastly, would a gas power trolling motor be better then an electric for salt water fishing? I will be fishing around Jamestown, Newport, and Narraganset Rhode Island.
Luna Sea
Re: Salt Water Trolling Motor
They do make some nice salt water electrics, but from what you've described, you're looking for a "kicker" motor. That would be a gas motor, 8-15 horse, and you'll need a mounting bracket. That will get you a heck of a lot farther than one of them battery powered ones..........
ratracer
Fully rigged your setup weights somewhere around 3000 lbs. If you insisted on using an electric you'd probably be looking at a 36V model with a total outlay (motor, batteries, etc. etc.) of over $1000, and I question whether you'd be happy with the performance in anything other then a dead calm, if that.<br /><br />Go with a gas motor. If you do a quick topic search here you'll find several threads about how to figure out the appropriate size.
