Sand in Exhaust Manifold - What to Do?
jmb23802
Pulled the risers on my 15 year old 243-hour 4.3 GL yesterday to get a baseline on their condition. Good news is, they looked great! Bad news is, I have a little bit of sand in the exhaust manifold now.
I had to use a real fine grit sandpaper (felt almost like emery board, but it was sandpaper) to prep the gasket surface on the manifold and when I pulled the rag out of the exhaust tube of the manifold some sand granules fell down inside the exhaust tube - not much at all but there was just a little and the sand was not much bigger than dust particles with maybe 2-3 that were slightly larger but still pretty small. I was short on time so I pushed ahead and reinstalled the riser (didn't have a vacuum handy). Now I am thinking I shouldn't have done that. To be honest, I am not sure if I have a vacuum that would pull them all the way up out of the manifold or not.
On one hand, I think they will probably blow out when I fire it up, and or not be a real issue. On the other hand, what if they don't blow out and find their way into a cylinder? What do you think I should do? Really don't want to redo all the work I did and shell out cash for new riser gaskets again for something stupid like this, but if there is a high chance it is going to trash my engine then I will do what I have to do. What should I do?
Grub54891
Exhaust always blows out. It will be a non issue. It'll blow out when you run it.
jmb23802
Thanks for the reply. That was my initial thought, but then I got to thinking what happens if, let's say, the grit slid toward the back of the manifold. During startup, which could take some cranking with my carbed engine, cylinder #2 "exhausts" first up the front channel of the manifold and blows the sand in the rear channel of the manifold down on top the valve in cylinder #4 or #6, then the valve in cylinder #6 opens and dumps the sand into the cylinder - some blows back out and some gets trapped. Perhaps I am overthinking. The amount of grit involved may not even be a problem, but I suppose the only way to be sure is going to be removing the riser and vacuuming the stuff out. Being stupid is painful!! haha
Your over thinking it. You could almost drop a pound of pebbles in the exhaust manifolds and fire up the motor and it would clear itself out
jmb23802
Sounds like I don't have anything to worry about so that's what I'll do: stop worrying. Appreciate the replies.
