My aluminum runabout has 1 coat of paint over the entire hull that someone rolled on years ago. The deck/hood is covered with a slightly tougher coating called DuraDeck...which the DuraTech company put on there 40 years ago. It's a bit tougher than paint, more like a very thin plastic texture finish. Which blast material should I be using with a 2200 psi power sprayer to get the paint and coating off? THANK YOU in advance.<br /><br />DJman
