- Jul 18, 2011
- 18,285
I have a fairly complete sanitation system on my 'new' boat, similar to the design illustration below . . .
the system appears to be designed to take in sea water as its water source for the toilet, and then I have it set to discharge into the holding tank (not over board).
I would like to avoid using sea water as the source, due to the increased bacteria count that would be introduced into the system. For now, I have been using water from the sink (i.e. the boat's fresh water system) to provide water for the toilet bowl. It is not a good solution over the long term though. . . .
I did a bit of searching here on iBoats, but did not come up with too much specific to my question/issue.
I would like to convert the toilet to use the boat's water supply (a pump driven pressurized system) instead of sea water. I could probably modify the toilet's supply plumbing and connect it to the cold water supply from the bathroom sink, but I am worried about all the things that could possibly go wrong at the toilet, in terms of it continuously letting water flow into the bowl, etc. I was thinking of a momentary valve of some sort that would provide a small amount of water to the bowl prior to/after use & flushing.
I'm thinking it would need to be fairly goof-proof, so the typical crew member could use the toilet without too much training, etc.
Any comments, experience, ideas in switching the toilet from a sea water supply to the boat's fresh water supply. ??? T.I.A.
BTW-the boat's water supply is not used for drinking water, as we carry bottled water (and beer) for drinking purposes.
