Satellite Radio - FM radio Hookup
mscher
Need some ideas here.
Satellite radios have basically 3 ways to hook to the vehicle radio.
1. Direct connect to an audio input on the vehicle radio.
2. Wire connect and adapter for a cassette tape on vehicle.
3. Transmit on low power FM frequency to vehicle radio.
I have a new Volvo big truck at work, and option 1 is not really useful , since there is only a "mono" input on the back of the radio and option 2 won't work anymore, as there is now a CD player. The company dosen't really want the radio replaced, or modified, since the truck is under warranty.
Used to use option 3 on older XM radios (before having a cassette player), which worked OK, but always had to be fiddling with the various FM frequencies, if I got too close that a actual, station using the frequency.
Now the FCC has forced lowered FM power on these radios, so the FM function does barely work, or not work at all. To counter the lower power, Audiovox (and probably others)includes a wired "clip", that is supposed to attach to an FM antenna, to presumably compensate for the weak transmit signal.
The clip option also does not work, as the Volvo has an integrated antenna setup, with the antenna built into the windshield.
Unfortunately, I will probably stuck making option 3 work :(.
The are some FM re-transmitter devices, such as the CCrane device, etc., that may do the trick, but need to make sure they work well before coughing up $50+.
Need help, as I'm going nuts from listening to NPR, endless depressing talk radio and top hits from the 60's, 70's, 80's, 90's and beyond ;)
i386
Re: Satellite Radio - FM radio Hookup
My suggestion...
Get an older XM MyFi off eBay. Mine was almost $400 new. They practically give them away now. They come with tons of accessories. The MyFi has its own internal FM transmitter and this was before the whole FCC/Clip thing. The kit will include a mobile and home antenna and various mounting options. Now, in my explorer I used the cassette adaptor because the FM transmitter didn't work that well for where I had my MyFi mounted down low. The FM transmitter worked fine, just not where I wanted to mount the radio.
I stopped using mine in my vehicle when I got my new truck w/factory xm. But I still have my MyFi. I bought one of those Altec Lansing docking things (eBay) for about $25 and now we listen to XM at the office on it. It also comes with a home antenna included.
Mike722
If you drive the same truck all the time, I got the antenna kit. You unplug the antenna at the back of the truck radio, plug it into a small box, plug the satellite into the box, and the box back into the antenna port on the truck radio. You still set the Sat. radio to 88.1 FM or whatever, but it is a direct connection and over comes any outside stations.
My brother has the attenna clip but I could not find one.
If you do not drive the same truck then you are stuck. One last option would be to get a boom box, if made for your Sat. radio style. We use one for the wifes radio. It has a docking station in the car and the boom box. Pull the radio off and slip it into the box for a great outdoor radio. Ours are Sirius but XM makes them too.
mscher
Great idea, i386, but I found something that may just be the ticket!
One of the things I hated about using the FM modulator, is that when I'm rolling into a city, I'll have to select another unused frequency, if the one selected was in use. This really stinks in cities like Chicago, where most of the frequencies are in use. I might have to switch frequencies 2 or 3 times, going through the city.
I found this powered unit that hooks into the FM radio cable. It is supposed to overpower any outside FM signals and give noise free input
http://tigerdirect.partsearch.com/Part/Audiovox+Corporation/Audiovox/XMFM1/New.aspx'
I'll let you know how it goes.
mscher
Mike, You beat me to it. I'll give it a try.
jimr
it will work great and also use any station you want. I have a similar setup for the sirius receivers I have
