Saving money on foam: bottles and other bad ideas.
lawyertob
Okay, I see all the time on here where people are using 20 ounce bottles to "stretch" their flotation foam in their rebuilds. I have even seen several times where people use Alka Seltzer in the bottles to repressurize them before foaming around them. And I even see people who use the single part household expanding foam (like Great Stuff) even though it is not approved for, nor intended for, marine use because it is "cheaper".<br /><br />Well, I decided to do a little calculating to see if any of these things were a good idea. I will put the majority of the calculations at the end...if you believe my statements you can read through the arguments easily...if you don't believe them, then skip down to the bottom and you can check my math. Nobody is perfect, but I think I checked everything pretty close.<br /><br /> Great Stuff??? <br />So, first I will address the Great Stuff foam. A 16 ounce can will make about 1/2 cubic foot of foam (see calculations below) and costs about $5. Therefore, Great Stuff costs about $10 per cubic foot. For ease of comparison, we can say that it will cost $80 to make 8 cubic feet of foam. Also, we can see that it takes about 2 pounds of Great Stuff to make a cubic foot of foam, so it can be compared to 2 pound marine foam. Well, except for the fact that it is neither approved for nor intended for marine use. Also, Great Stuff is a one part foam that uses moisture in the air to cure. It will not cure properly if used to fill large voids unless applied in layers. In fact, it is not intended for voids larger than ½ inch and is not intended to provide structural support. It is water resistant but it is not waterproof and will eventually absorb water.<br /><br /><br /> Marine Foam <br />On the US Composites web site, you can get an 8 cubic foot kit of two part 2 pound marine foam for $48.00. This works out to $6 per cubic foot. Shipping adds about $1.50 per cubic foot for a total of $7.50 per cubic foot. <br /><br />You can get two four cubic foot kits, for a total of 8 cubic feet, of two part 4 pound marine foam for $96. This works out to $12 per cubic foot. Shipping adds about $3 per cubic foot for a total of $15 per cubic foot.<br /><br />Both of these foams will cure properly in large voids because they are two part foams. The 2 pound foam, though water resistant, will eventually absorb water. The 4 pound foam is much denser and is considered to be waterproof.<br /><br />In addition, the 4 pound foam is MUCH stronger and provides nearly as much flotation compared to the normal 2 pound foam. Check out the web site and they give all the tensile and compressive strengths.<br /><br /> In any case, we can see that it is actually cheaper to use a proper 2 pound marine foam than the Home Depot stuff. It is only a little more expensive to use the much stronger 4 pound foam. <br /><br /><br /> Bottles to "save money" <br />Now we come to the widespread practice of putting bottles in with the foam to "save money" on foam. There are about 7.5 gallons in a cubic foot. Even if we assume that each 20 ounce bottle actually displaces 24 ounces (since they are never completely full), it still takes 5.5 of them to make a gallon and about 41 to make a cubic foot.<br /><br />If you use the Alka Seltzer method of placing a bit of water and an Alka Seltzer in each bottle to repressurize them it really starts to not make sense.<br /><br />Alka Seltzer cost about 5.49 for a 36 count box which works out to a little over 15 cents each. Therefore, to pressurize the 41 bottles would cost $6.26. In other words, it would be cheaper to use 2 pound marine foam than to pressurize bottles with Alka Seltzer (not counting shipping).<br /><br />Not to mention the fact that a resealed bottle probably isn’t going to hold pressure anyway. If it doesn't hold pressure, then the bottle provides very little structural support, and could lead to structural failure of the foam around it.<br /><br />Even if it does hold pressure, then you have to worry about the bottle expanding and contracting with changes in temperature. This expansion and contraction would cause voids in the surrounding foam which could collect water and also cause a loss of structural support. Even a bottle that was not repressurized would expand and contract if it had a good seal from the air inside.<br /><br />Generally people use liquid nails or the equivalent to hold the bottles in place prior to foaming around them. Liquid nails costs $2 a tube and it just so happens that it would take almost exactly a tube worth to put two quarter inch beads on each of the 41 bottles (I can prove it if I have to, but the math is getting a little boring). What? You don’t believe me…well fine...32 feet of ¼ inch bead per 10.5 ounce tube. 32 X 12 = 384 inches. 384 inches divided by 41 bottles yields 9.36 inches per bottle… which is just about exactly how many inches it would take to put two beads down the sides of the bottles.<br /><br /> So it ends up costing $8.26 per cubic foot to use repressurized bottles held in place with liquid nails. This is more than the cost to use a 2 pound marine foam. <br /><br />==================================================<br /><br />Okay, I apologize for this being so long winded, but there were a lot of calculations and it couldn't be condensed too much more and cover all the points that needed to be addressed. The conclusions that I reached are just my opinion, but at least I have figures to back that opinion up. I, for one, will be using 4 pound foam without any bottles, in case you haven't already guessed. ;) <br /><br />Just my $0.02 worth,<br />Joe <br /><br /><br />=================================================<br />Great Stuff calculations<br />A 16 ounce can of Great Stuff produces 335 feet of a 3/8” by ½” bead (this information came from the manufacturer's web site Great Stuff FAQ ). Therefore, .375 X .5 X 335 X 12 = 753.75 cubic inches.<br /><br />1728 cubic inches in a cubic foot. 12 X 12 X 12 = 1728.<br /><br />753.75 divided by 1728 yields the fact that a can of Great Stuff produces .44 cubic feet. So lets give them the benefit of the doubt (and make the math easier) and say that a can of Great stuff will make one half of a cubic foot of foam.<br /><br />A 16 ounce can of Great Stuff costs $4.97 a can, lets call it $5 for ease of calculation.<br /><br />Therefore, Great Stuff costs $10 per cubic foot of foam.<br />==================================================<br /><br />1728 cubic inches in a cubic foot<br />231 cubic inches in a gallon<br />7.48 gallons per cubic foot ( I know it sounds like a lot but it is true)<br />128 ounces per gallon<br /><br />128 / 24 = 5.5 bottle to make a gallon<br /><br />5.5 bottles times 7.5 gallons = 41 bottles per cubic foot
jimmythekid
Re: Saving money on foam: bottles and other bad ideas.
what are the other bad ideas?
snapperbait
The appropriate (2 or 4lb.) foam also provides structural ridgidity, and a great deal of sound deadning, where bottles and other containers don't....<br /><br />Gimme foam! :)
JasonJ
Good job Joe, you have done a lot of research to help prove my point: Just use the darn 2 part foam and get it done. I still have fond memories of the E-war I had with another poster about Great Stuff. Fun was had by all.
swimmin' for shore
Good God, Joe. That's quite some figuring. What did you do for the Navy? ELT? That would actually be a really good guess. Lab tech, if you aren't familiar with Navy rates. Very good opinion, though. I hope others can come up with some good ideas. I missed that in my "Fancy thinking" thread, but I'd love to hear any other "bad ideas". I actually have one, or I believe it's a bad idea. <br />Fiberblass gas tanks. I don't have Joe's math down, but I'm guessing that a fiberglass tank would weigh more than a gas tank. It may do the trick, but a lot is lost in weight, safety, and questions about whether or not the tank will hold up to things like ethanol. I know for a fact, without debate, that fiberglass isn't going to hold up if there's a fire. For a few hundred dollars, or a tig welder(I have this capability), my money's on aluminum.
18rabbit
I thought about the bottles back when Boomyal was skipping his meds. I figured the bottles don’t cost anything because they are laying around anyways, you don’t need them to be airtight because they will be encased in surrounding foam that is airtight, don’t want or need any water or seltzer in the foam (the heat from the curing foam should keep the bottles inflated IF fully enclosed), not using foam for structural support…just to displace water only in the event of an emergency (why the foam is even required in the first place). In this case, bottles are a lot cheaper than foam.<br /><br />If the foam is not for structural support, you don’t necessarily need it to be solid. (See last paragraph.) I thought about the idea of using something inflatable like a plastic bag in the center. The heat from the curing foam could cause the air in the bag to expand and burst the bag…but you get the idea…something cheap that will create a big, enclosed air pocket inside the foam. If the void is too big it’s possible a cooling could cause the air pocket inside the foam to condense and collapse the sides of a large foam block. (See the thread on collapsing batteries). At 14.7psi (atmospheric pressure at sea level) you have about a ton of pressure on one square foot of surface area. But you won’t have an absolute vacuum inside your void. If you have 3 sq ft of foam surface area with a void below it and only a 5% condensing of the air inside that void, that’s 300lbs of pressure distributed across 3 sq ft of unsupported foam surface.<br /><br />I’m not convinced soda bottles of air will weaken the foam’s supporting ability. Little sealed bags of air are used to support stuff in shipping containers all the time. If the soda bottles are scattered about in the foam and fully enclosed, I don’t see a problem if a couple inches of foam cover the bottles. If the bottles are all bunched and stacked, there could be problems. Btw, if you are using the foam for support, 4 lb foam should be a consideration.<br /><br />If you were to glass in pvc tubing for water flow channels, you can create compartments that are total sealed airtight with fiberglass and avoid the foam altogether. But like foam with a big internal void, it only works for boats that are swamped. It is possible that a collision could compromise the compartment (or foam with an air pocket) and suddenly your means of floatation becomes a container to hold water...on its way to the bottom.
Snookster
I actually had a guy I know in St Pete that rebuilds boats that swears, adding ping pong balls to the slurry foam fill makes his boats unsinkable<br /><br />Just an instresting alternative.
jimmythekid
how much do ping pong balls cost?? maybe we could put big inner tubes under there and just pump them with air every once in a while J/K hee hee
lawyertob
Originally posted by jimmythekid:<br /> what are the other bad ideas?
Jimmy,<br /><br />Alka Seltzer to "save" money, household foam to "save" money.<br /><br />$0.02 redux,<br />Joe
AMD Rules
Ping pong balls sound like a great idea in that they are sealed, they are round thus strong for support, they are permanently waterproof. Only downside would be availability & cost. I'm condident Joe can help us out with the cost estimates.
Boomyal
Originally posted by AMD Rules:<br /> Ping pong balls sound like a great idea in that they are sealed, they are round thus strong for support, they are permanently waterproof. Only downside would be availability & cost. I'm condident Joe can help us out with the cost estimates.
Oh Oh, here we go again :D :D :D
lawyertob
AMD,<br /><br />Believe it or not I have actually looked at this. I have heard that you can get the ping-pong balls for 10 cents each, but the best price I have actually found is 20 cents each.<br /><br />The volume of the ping-pong balls is given by the equation 4/3 X pi X (radius)cubed and the radius of a ping pong is .75 inch. Therefore, a ping-pong ball has a volume of 1.77 cubic inches. This means that it would take 978 ping pong balls to make 1 cubic foot (this assumes that foam would go into all the spaces between the balls, which means it doesn't matter how the balls are stacked). From this, it can be calculated that it would cost somewhere between $100 and $200 dollars to buy a cubic foot of ping-pong balls.<br /><br />Basically, it is WAY cheaper to use foam than to use ping-pong balls!<br /><br />[EDIT - I had a transposed digit in the original calculation, found it after checking my figures again.]<br /><br />Just my $0.02 worth,<br />Joe
lawyertob
Originally posted by swimmin' for shore:<br /> Good God, Joe. That's quite some figuring. What did you do for the Navy? ELT? That would actually be a really good guess. Lab tech, if you aren't familiar with Navy rates. Very good opinion, though. I actually have one, or I believe it's a bad idea...Fiberblass gas tanks....For a few hundred dollars, or a tig welder(I have this capability), my money's on aluminum.
Swimmin'<br /><br />Actually I was a nuke machinist's mate. (waiting for the F'in nuke jokes) As for the fiberglass fuel tank, epecially of the home-made variety, I would have to say that it is such a bad idea that I don't even need to discuss it. Aluminum is pretty good stuff, but it still corrodes, unlike plastic. Of course for a really large capacity tank I might go with aluminum for structural strength.<br /><br />Oh, before I forget, have you thought about the difference in cost of building fiberglass coolers compared to the cost of buying some big coolers? Even if you bought the big coolers and used them as a base and just glassed around them it would be cheaper than building from scratch. And no, I haven't run the numbers, but I would be willing to bet. ;) <br /><br />Anyway, what do you do in Uncle Sam's Canoe Club? You mentioned once that you were going out to chase subs. If you are ASW remind me to tell you some Autech stories sometime.<br /><br />Just my $0.02 worth,<br />Joe
a_bullfrog_a
where do you shop?<br />try Wal-mart=<br /> GreatStuff- $3.88 (tis the season for winterizing)<br /> liquid nail- under $1.50<br /> store brand alka selter- 70 so count under $2.00<br />never tell anybody how much you've paid for something. they'll just rub in your face you paid <br />too much or din't get the very very best.<br /> buy+hush= happy
lawyertob
Originally posted by a_Bullfrog_a:<br /> where do you shop?<br />try Wal-mart=<br /> GreatStuff- $3.88 (tis the season for winterizing)<br /> liquid nail- under $1.50<br /> store brand alka selter- 70 so count under $2.00<br />never tell anybody how much you've paid for something. they'll just rub in your face you paid <br />too much or din't get the very very best.<br /> buy+hush= happy
Bullfrog,<br /> <br />Well, as a rule I avoid Wal-Mart...and no, I don't want to get into a discussion of whether Wal-Mart is evil or not. ;) The prices I quoted were from Walgreen's and from Home Depot...and were for illustration purposes only.<br /> <br />Even so, at that price, the Great Stuff still costs more than the proper marine type foam. And it is still not going to cure properly in large voids over 1/2 inch, still not going to be waterproof, etc.<br /> <br />As for the bottles, I don't think they are good idea for structural reasons as explained above, and I certainly doubt that they will hold pressure for long with or without Alka Seltzer. And even at the evil Wal-Mart prices you are going to spend almost $3 a cubic foot for bottles and seltzer when you could have used foam for a few dollars more...and this doesn't even consider the time it takes to mess with all those bottles instead of just mixing and pouring foam.<br /> <br />Anyway, opinions are like...well, like navels :) we all have one.<br /> <br />Just my $0.02 worth,<br />Joe
AK_Chappy
Wow,<br />Joe you did some figuring there!<br />4 lb foam it is for me.<br /><br />AK Chappy
Winger Ed.
Originally posted by swimmin' for shore:<br /> that fiberglass isn't going to hold up if there's a fire.
This is very true. But then again, I think having a metal tank just for that, is sort of a solution for a problem that doesn't exist.<br /><br />By the time a fire gets so far out of hand-- even with the tanks under the splashwell in a smaller boat-- that the tank is engulfed to the point it fails or melts......<br /><br />I'd have been over the side and 'dog paddeling' for shore long before then.<br /><br />For the ones mounted several feet away from the engine-- where most fires start-- as most are, there has to be one heck of a blaze going to reach it.
swimmin' for shore
Some various thoughts here, but I'm running ideas for the cooler. I remain undecided yet, but I'll get it figured out. Part of it has to be that most of what I would use to build a cooler is leftovers from the deckwork. I have ordered 2 lb. pourable foam, and with 10 gallons en route, I have way more than enough. It'll seem like overkill, but it was at a really good price. I'll also have leftovers from the deck, I'm sure. I have more than enough cloth epoxy. The rest is just wood, and this is probably the one thing I'll have to buy extra for. So, if using materials that would have just ended up in the garage anyway, it's only a matter of my time. Time, I have. <br />Happy Thanksgiving. <br />Joe, I'm one of the NDT inspectors. If you're unfamiliar, it's non-destructive testing for welds and brazework. That said, I'm a glorified HT. Under the circumstances, I'm going to avoid any nuke comments. Besides, I have one sitting here next to me, and he's a pretty big guy. :) <br />Re: gas tank. I really played with that idea, to go fiberglass, and lay them between my stringers, with access covers through the deck. It wouldn't be so hard to build, but I really don't want to take a chance on cracking them somewhere down the road if I were to run it aground hard. While I can't imagine that, there are a lot of things out there where it is better to just be safe than sorry. Fuel is one of them. The idea isn't gone completely yet, but now I'm trying to figure out how to build the accessories into an aluminum tank. As always, money will dictate.
Marc J.
Glad to hear that the flotation debate lingers on. I plan on stuffing all the open areas in my floor with water noodles. I managed to score 60+ of them for 50 cents a piece at the local Big-K a few weeks back. Since they are the hollow type and rather soft, I believe they will conform to fill the compartments if I slighty pack them down with the new flooring (not so much as to squeeze the cells) and screw into the stringers. I know it sounds bad, but it's cheap and easy.
lawyertob
Originally posted by swimmin' for shore:<br /> I have ordered 2 lb. pourable foam, and with 10 gallons en route, I have way more than enough. It'll seem like overkill, but it was at a really good price.<br /><br />Joe, I'm one of the NDT inspectors. If you're unfamiliar, it's non-destructive testing for welds and brazework. That said, I'm a glorified HT. Under the circumstances, I'm going to avoid any nuke comments. Besides, I have one sitting here next to me, and he's a pretty big guy. :)
Swimmin',<br /><br />Hmmm, an HT who was going to pass up a chance to weld something and make it out of fiberglass...what is this world coming to. ;) My grandfather was an HT...though I think they called them something else back then. In any case, I am glad that you are a snipe and not a twidget. ;) I did a little NDT work myself and a lot of hydrostatic stuff and freeze seal work...which meant I had to get one of you guys to come and tell me that something was in fact welded a lot of the time. :) <br /><br />Now, what in the heck are you going to do with 40 cubic feet of foam? I might get a little 2 pound for some non-structural above deck flotation, but I probably won't use more that 10 cubic feet of either density in the whole boat. Heck, if it wasn't going to take you so long to get back off the big pond, I might buy some of your extras. ;) <br /><br />Anyway, look at my profile and drop me a line on my e-mail and we can swap sea stories, without clogging up the forums.<br /><br />Another $0.02 worth,<br />Joe
