SBC V8 PDS Seals
LegacyT
I'm in the process rebuilding my flywheel housing. I have the pds shaft and bearings out of the housing.
As for grease, I have Marine wheel bearing NLGI 2 grease. Is this what people use? No info in the service manual, they just state grease..
Thanks,
Mark
Re: PDS Bearing Grease
Ayuh,.... See below,....
V
V
V
V
V
V
V
V
V
V
V
V
V
V
LegacyT
SBC V8 PDS Seals
I'm reassembling My flywheel housing on my aq231a. Its the 2 bearing setup. I ordered the 2 sealing rings as per the VP parts schematic and the fwd and aft are the same part number. Now looking at it the u joint spline is smaller then the flywheel spline. The fwd seal is 35x62x7 mm but the other one is too big. Does anyone have the correct part # or dimensions of the aft seal? I already threw out the old seals to compare :facepalm: Or does the female end of the u-joint yoke seal using the larger seal i got??
Thanks,
LegacyT
Re: SBC V8 PDS Seals
perfect the answer I wanted to hear! Thanks
