Scanreg/fix??
dolluper
Have I got this right for windows 2000 sp4 or should I update to sp5 before running
F8>>safe mode>>start>>run>> type . scanreg/fix
or is the route wrong .......thanks
Plainsman
Re: Scanreg/fix??
Not sure about that, but you can start in safe mode with command prompt and type chkdsk /F that will check your file system.
dolluper
Re: Scanreg/fix??
It's for fixing bad values in the registry,bringing this old lap up to date what a chore,not updated since 2000
Plainsman
Re: Scanreg/fix??
If it's been sitting that long, why not just do a total restore?
dolluper
Re: Scanreg/fix??
Man I've done lots I'm in the final stages,just want to clean some funk out of the registry and it's good to go
Plainsman
Re: Scanreg/fix??
Why do you believe you need to clean up the registry? Are you geting errors? Programs not running correctly?
In XP pro if I do a scanreg /? I get C:\Documents and Settings\user>scanreg /?
'scanreg' is not recognized as an internal or external command,
operable program or batch file.
What do you get if you run "scanreg /?" ?
BoatBuoy
Re: Scanreg/fix??
Scanreg is not an NT tool (i.e. Win 2K, Win NT 3/4, Win XP). It is only for Win 98 and ME. Even if you find a copy of scanreg from an older machine, I wouldn't use it. NT registries are quite different from '98.
To answer your question, I always try to get the latest SP on as quick as possible. I think the latest one for w2k is sp4.
dolluper
Re: Scanreg/fix??
Thanks BoatBuoy your right ,this lap had win 98 before and it had the Ms utility,you got me on the right track now.Guess I'LL search C and see what's still hanging on
Xcusme
Re: Scanreg/fix??
Yea, SP4 was the last service pack for Win2k....MS dropped any plans for SP5......
