Ok, my boat is having a dual battery setup installed as I write this. Now, my plan is to crank the boat on both batteries and when we pull into a cove and turn on the music, switch to the #2 battery (deep cycle). Switch back to both batteries when cranking back up. My question is, since some folks use only the cranking battery to start the boat, does the second battery get charged even if the switch is just on the first battery? I would think not, but just wanna make sure that to charge both batteries, the switch needs to be set on "both". Do I have this correct? Thanks!
