deleted_d13mille
- Nov 5, 2001
- 1
Does anybody have any info on a 70 hp Merc oil injected engine, 3 cyl. The problem is the top cylinder has a scored piston and the cylinder sleave has turned about 1/4 inch in the bore which now the port holes are partially obstructed. I've talked to some Techs and they say that a cylinder can turn if the engine should over heat. Also they said that this is common for those engines. The lower two cylinders look perfect. The engine did not run out of oil nor did the water pump fail as both of these items are working fine. My question is if the Tech I talked to is correct then there should be others with the same problem. Is there anyone out there with this problem. Because if it is I will not have this motor for long. Thanks
