Re: scott mcculloch 1960 40hp
I dunno what the official full charged battery voltage is, 12-point something, with no load on it. I never considered it really that important, but somebody will dispute that. Most regulated charging systems put out about 14.5 DC volts. Yours isn't regulated. If you check the coils' voltage while running with no rectifier, or not connected to a battery, they may go sky-high, even as much as 100 volts AC. That is why you must not run the motor with the battery disconnected--the high voltage will blow the rectifier. Of course if you check the coils voltage with everything connected, it will be the same as battery voltage, but AC. Well, almost. You have to allow for voltage drop across the diodes, and stuff like that. Now we are getting complicated again.
