Scratch in gelcoat
dui9402
I got a pretty deep scratch in my gelcoat, down to the fiberglass in one spot. What should I use to seal it? I'm also wondering what the best product to seal screw holes is. Thanks.
Plainsman
Re: Scratch in gelcoat
I have used Marine-tex for screw holes. Hardens real nice and can be sanded.
ondarvr
Most marine supply stores and many hardware stores sell gel coat repair kits, some come with pigments to help tint it for a better match, it's very easy.
dtherrien
For minor scratches and repairs...use the gel-coat repair kit. After the scratch is filled,Use wet dry sand paper....start with 220 if you need to shape the patched area. Continue going finer...400, then 600 then 800....then a couple coats of rubbing compound followed by three coats of wax. It should look pretty desent when your done.
