Screaching Sound when I Start the Engine
greg82255
Hello,
I have a '82 Merc 898 (305 ci). Have had several problems (as my previous posts would suggest) and here is the latest. I was on the water today and I turned off the engine so one of my friends get back in the boat, and I go to start it up again, and I hear a "screachhh" sound when the engine is cranking. The screach is only for an instant (maybe half a second at most), and then boat starts up and runs just fine... It does not sound like any grinding of the gears, it just sounds like a loud squeak/screach. any ideas what this may be?
Just another thing that the mechanic is going to have to look at this week..
skipdow
Re: Screaching Sound when I Start the Engine
my uneducated guess would be a bad starter. If you can borrow one then see if alls good.
Thats also assuming you checked all the particulars like oil, water , temp etc.
ecriswell
Loose or worn belt(s). Almost guarenteed.
skipdow
usually belts are when it has started not while it is cranking...unless something has a bad bearing like a sea water pump or an alternator
SSSuper83
Not true my friend..a power steering pump pulley will squeal all day from start if its loose..any belt will squeal at start if it's loose...
greg82255
Thanks everybody for the responses. I hope you are all right and it is just a loose belt. Just to be clear, this problem is only at start, goes away once the motor is running.
I will tighten them all tomorrow and re-post.
greg82255
Just an update - the problem was the belts. One was way too lose, causing all kinds of noise. I tightened it and the problem was solved. Thanks everyone for the help.
cr2k
It was the one on the alternator wasn't it?
