screamer
azzhol88
I just purchased a 1960 hall craft,Hull is in great shape however the V-drive has a high pitch scream,what could it be the alinement or mabey the oil,it looks and smells like ATF fluid is that right. :confused:
airman
Re: screamer
My xmission (Borg-Warner Velvet) uses ATF but my Walter V-Drive uses 30W oil. Not much that can be done to mine in the boat, it sounds like a bearing has died. Maybe its got ATF where it should have got oil? (ouch!)
a.d.mobile
Re: screamer
are you hearing this scream while boat is out of the water in gear?
azzhol88
Re: screamer
it makes no diferance if its in or out of the water,I hook up the hose to the water pump and it makes the loop through the V drive to cool.
