Hi guys,
I just recently purchased a 1988 50HP Yamaha 2 stroke outboard off of ebay locally. When the outboard starts, it will give a couple of short screeches as it warms up, then appears to idle fine. When you start to give it a little gas and let the rpms start to climb, you'll get some hesitation, a short 'screech', a puff of smoke from the exhaust from the front of the motor (at about where the hinge/bracket is) then a small splash of oil/fuel mixture from the same area.
Any ideas? Would the reed valves make a short 'screech' sound?
The gentleman I bought it from said he had cleaned the carbs the day before.
I plan on pulling the plugs in the next few days to check them.
Any suggestions or advice is greatly appreciated. I like to think I am mechanically inclined, but this is my first experience with 2 strokes.
Thanks in advance for taking it easy on a newbie.
