Update: Solved the screeching and smoking, but still struggling with a high idle. Any help with this issue is appreciated. More details below.
Hi Everyone,
Year: 1996
OMC 5.0 FI (ford 5.0)
Model #: 50FAPNCA
Serial #: T01288736
I have been trying to learn as much as I can from this forum without being a pest. Thankfully, I usually find what I need without asking...but my searches came up empty this time. Please Help! :blue:
My wife and I bought my boat last fall. We replaced the interior, fixed the trailer, gas lines, etc. I had a local (and well respected) marine shop perform a compression test, engine tune-up, drive service, and water pump this summer. On their water test, they discovered cylinder #1 wasn't getting any fuel. They were willing to keep working on it, but wouldn't get to it until after July 4, so I tackled the job myself.
I took my stethoscope and confirmed cylinder #1's fuel injector was not firing. A local injector specialist checked/clean all the fuel injectors and confirmed the Cylinder #1 fuel injector was dead. I bought a new injector and installed it. I confirmed the new injector was firing with my stethoscope.
We took the boat out for the first time since the work tonight. The boat was an entirely different animal. It was pure bliss. We cruised around the lake at 25-35 mph for about a half hour. I then decided to open it up. It took off like a rocket all the way 65 mph, which is about 10 mph faster than we have seen. WOT was less than 5 minutes total.
We then idled in/out the channel which took probably 30 minutes. On the way back in, I noticed the idle speed was surging +/- 100RPM. This seemed to follow the waves though. I assumed it was the wave hitting the thru-hull exhuast.
We then cruised a bit more, but when I opened the boat up again, top end was only around 50mph. Frustrated, we called it a night and cruised back to the launch. At the ramp, we discovered our idle was no longer surging, but at 1500 rpm. (normal 600)
High idle. Loss of power. No other symptoms.
As we pulled it out of the water, I noticed the swim deck had black silt on the right side (cylinder #1). I thought to myself..."Eureka, who knows how long that fuel injector was dead. It probably has years of carbon built up in that cylinder. I bet it fouled the plug. I'll replace the spark plugs again and sea-foam the engine tomorrow. This is going to be easy. :facepalm:."
In the driveway 45 minutes later, I decided to make sure my new fuel injector was firing. I started the engine up (on a hose) and heard the worst screeching noise I heard in my life. It seemed like an eternity, but in reality I killed the engine in less than 3 seconds. Then white smoke started pouring from the exhaust.
Any ideas? I really hope the motor isn't toast. I don't understand how an engine can go from awesome, to mediocre, to worthless in one evening. My wife (and I) will be crushed if the motor is gone.
Please help if you can. Thanks!
Eric
Hi Everyone,
Year: 1996
Model #: 50FAPNCA
Serial #: T01288736
Eric
