bayoucat58
- Jul 9, 2011
- 71
But what is the real difference between in board vs. out board rotation when setting up a small say thirty foot vessel
Much better handling with counter rotating engines and props. Some Mfg's even counter rotate props on the same shaft on an outdrive. Normally with duel engines the props rotate outboard.
(do I make any sence?)
Hi Sasto, yes you make since so in your opinion whether they rotate in board or they rotate out board makes NO difference so long as they are countered. OK Thanks for hitting me up with that information Bonn Voyage!!!
