imported_KEEPER
- Mar 10, 2007
- 8
Heard a tapping sound from my starboard eng on sat. Determined noise was from starboard head. Pulled head and found two pistons with 1/4 round brass imbeaded in pistons. Found the source of the brass was from two different carb throttle body butterfly screw heads that had sheered off. 1997 yamaha SSII. I need some advice.
I removed the screw heads which left an indentation. Should I put it back togeter or replace the pistons?
The threaded part of the screws are still in the throttle shafts and seam tight. Should I ping them in or try and remove them. There are two screws in each butterfly.
I will remove all the carbs and inspect the screws. This engine had the powerhead replace when it was a year old. I believe that someone check and over torqued them at that time.
Thanks,
Thanks,
