screwed up and dropped my float!
Redkneck
Was thinking my 170 was flooding so I was gonna take a look at my float, needle and seat and I accidentally tilted it sideways like a doofus and outpopped the pin, float hit the floor, needle was recovered too, but I think I am missing a pin and spring that go under the needle. Advice? Order a complete rebuild kit? Are all the 170 2bbl carbs the same?
Thanks in advance!
thumpar
Re: screwed up and dropped my float!
If it is a rochester you can probably get the parts at Napa.
Redkneck
How do I tell if it's Rochester or mercarb?
matt167
Rochester will say " Quadrajet " on it
thumpar
How many mixture screws do you have on the carb?
matt167
They used 2 barrel carbs.
Ah, yes. I was thinking of the 488's which did use a 4bbl.. Roch carbs are usually marked tho. Would be a 2G if Roch, as I don't think the Dualjet was ever used for marine engines
Redkneck
Yes it has the single idle mixture screw, thanks as always Terry! I dropped the little pin and spring that go inside the needle into the bottom of the hull. I'll just order that whole group thanks!
spdracr39
I would consider getting the float also just in case it was damaged.
Zeus88
I did the same thing last week. I just got a whole kit. Make sure you follow all he adjustment tips
