Greg Lawrence
- May 18, 2002
- 263
Wednesday evening was slightly choppy on the lake, tide was out, and slight breeze. Ran WOT up to 5380 RPM is where it maxxed due to the chop couldnt trim out anymore due to stability. Saw some birds about middle of the lake and head for them. Slowed the motor on the approach, and it died completely. Pulled the plugs, not fouled, check everything, couldnt find it. Guy I knew happened to be crossing the lake and gave me a tug. Today I got around to looking at it. Two of the three screws on the carbs that block off the jet at the top were gone! Found one in the lower motor and have no clue about the other one? So the motor was sucking air i suppose as those are the low speed jets? idle? Are you supposed to put loctite on em?
