Re: Sea Doo Challenger
Personally I like the handling of the Jet you referenced. I have never owned one but often use and go along with a neighbor that has one. I suggest driving one, especially if you're buying new. You'll need to determine if the navigating characteristcs are suited to your needs and use.<br /><br />Steering is less than desirable at low speed, and as mentioned above, reverse is not much better due to the mechanics and attributes of the "jet" function itself (work just like aircraft reverse thrusters). I wouldn't recommend buying without driving.........
