One thing to consider is that it may have the old style grey tempo fuel lines. If it does, you will need to replace them, as they are well known in the SeaDoo community for clogging up the fuel system with green "goo" on the inside. Other than that, I have a 1995 GTX that run very well. If it does have the grey tempo fuel lines, don't let that stop you (I replaced mine), but be aware that after replacing them, you will more than likely have to have the carbs cleaned and overhauled.
