Re: Sea Foam or Mercury Product
You read the instructions and just squirted some in the cylnders? It dissolves some things at room temperature, but carbon ain't one of them. The motor has to be warm and running. You spray it into the carbs of a running motor until the motor labors and dies, then let it sit for a few hours. That's when that stuff works. The instructions should be on the can. Merely spraying it into the cylinders does next to nothing. 1 can should treat four V-6 motors.<br /><br />There's something really cheap that'll clean the combustion chamber. Water. Good old H2O. Spray a fine mist into the carb(s) as the motor is running at high idle. It steam-cleans the pistons and cylinders. You don't want to spray so much that it kills the motor. For a few minutes. Then fog the motor or just take it for a ride. It won't take long to work the water out, just don't shut it off and let it sit wet.<br /><br />When I buy a used outboard, I do both. In that order. Power Tune loosens things up, water steams it away.
