Sea Foam question
ddennis
Ok Guru's. I finaly found some seafoam, however they did not have deep creep. My engine is a mid 90's 15hp with a single carb, can I just put some of the seafoam in a spray bottle and mist it into the carb. OR is Deep creep different from the liquid seafoam? :}
Texasmark
Re: Sea Foam question
Only difference is there's no lablel on the container, probably plastic rather than metal, and your finger is the propellant. Same stuff.....says so on the can (if you had one). 8)
I use it in everything that runs.
Mark
ddennis
Thanks Mark! I will buy a little squirt bottle today and fog it tonight!
casi77
i would just dump the seafoam in the gas tank (gas+oil tcw3 mix) and run it till it finish, you'll see difference then.
Deep creep (the spray type), or regular can type in a spray bottle.. there is a method of de-carbing, search this site..
Seafoam : http://www.seafoamsales.com/products.htm
gss036
Just use it in your fuel if you want to clean up the internal fuel system/carb. I suspect you are using a small tank, so best results will be obtained this way unless you feel that you need to decarb. Follow the below idea for spraying into spark plug holes or mix a very strong solution (1 can/1 gal gas/TCW3) and run the engine.
Spraying directly into your carb will have a tendency to wash away the oil which is your lubercation for the pistons/rings.
The only time you need spray is if you remove your spark plugs and spray into the holes onto the top of the pistons. Common sense should prevail in these situations.
ddennis
Now I am confused. How do I safely decarb this engine? I do not want to cause any damage or shorten the life of the engine.
Thanks!
tashasdaddy
running it in the fuel is more of a preventative. you can warm the engine up on muffs, and spray into carb. this is a higher concentration than running in gas. spray it in to where it almost stalls, this is what breaks up the crud in the engine (it's gonna smoke like it's burning up) keep doing it until to smoke lightens up. then running it the gas will help clean the carb, but if the carb is really varnished up, the only help is a disassembly, soaking, and a rebuiled kit. there is nothing in seafoam that will hurt your engine. NEVER use starting fluid on a 2 stroke engine.
ddennis
carb is just rebuilt so thats not an issue, This is a new to me engine adn I figured it needed to be decarbed just in case.
Thanks for the info guys!
artherm
artherm
You can find "Deep Creep" at O'Rielly Auto Parts.
Silvertip
Deep Creep is simply the spray version of SeaFoam. You can use SeaFoam in a spray bottle.
hkeiner
Anyone have an opinion on Berryman's B-12, as a gas additive, in lieu of using Seafoam? It is sold at Walmart.
