Sea Foam???
JGREGORY
I've heard people talking about this as a additve to clean your carbs/engine. But I've never heard of it where is it availabe at and can you purchase it on line. My 650 merc is spewing alot of black crap onto the ground when run with the muffs and since the engine has sat for 2years i figure it could use a decent carb cleaning but do not want to use reg. carb cleaner because of the lubrication issue. I tried finding the web site with no luck so any here would be appreciated.
mellowyellow
Re: Sea Foam???
for sale at Nappa auto. sounds like you could use<br />a good de-carb.<br />good luck,<br />M.Y.
Kenny Bush
Re: Sea Foam???
NAPA auto stores. SeaFoam "Engine tune". Put a can in your tank every 3rd fillup and you will be clean all the time. God I sound like a commercial....... :D :p :) :cool:
mellowyellow
Re: Sea Foam???
bushcat gives good advice to prevent carbon build-up, <br />but you may wanna consider a more thorough<br />decarb the first time. this is where you spray<br />a can in each carb, let sit for a while, then<br />run it and watch tons of crud come out.<br />directions on aerosol spray can. been discussed<br />here several times and can be found with a search.<br />good luck,<br />M.Y.
Fouled Plug
Ensign
Re: Sea Foam???
Yep, Deep Creep (aerosol SeaFoam) for initial decarb, and use the additive in the fuel to keep it clean. You won't believe the crap the decarb will flush out! Don't point the exhaust at anything you would like to keep clean...lots of black junk and smoke will come out when you refire for the first time. You will want new spark plugs, or thoroughly clean your current ones after the aerosol treatment.
Zac
Re: Sea Foam???
I think marvel mystery oil is the does the same thing
