sea foam
procraftmark
Is it a good idea to use sea foam as an additive to your gas to reduce carbon buildup and will it really work on an older 1989 50hp force<br /><br /><br />thnx<br />mark
JB
Re: sea foam
Outboard Non-repair topic
roscoe
Re: sea foam
Yes, that is exactly what it is made for.
rathrbfishin
Re: sea foam
I bought a motor that was 10 years old. Used sea foam , motor ran better and even gained 300 rpm's. Great stuff !!!!
procraftmark
Re: sea foam
rathr<br /><br /><br />did you add that to the gas or run it thru the carbs?<br /><br /><br />mark
05GlastronSX
Re: sea foam
well, if you add it to the gas it will evnetually go through the carbs so either way i dont think it matters...but i may be wrong..
roscoe
Re: sea foam
You can use it in the fuel at 1 ounce per gallon as a stabilizer and fuel system cleaner, as well as prevention of carbon buildup.<br />At high concentrations, it can be used to decarb the motor.<br />But I buy and use the aerosol version (Deep Creep) when I decarb.<br /><br /><br />note, this is not a substitution for a real carb rebuild.
