Sea Foam ??
rolmops
Hello.<br />Can anybody tell me what sea foam is and does?<br />How do I get in the engine housing of my old '57 35 horse Seahorse and what do I do to get it out?<br />Thank you for your response.<br />Cornelis.
StriperChaser
Re: Sea Foam ??
Sea Foam is a product used to clean carbon from auto and marine engines. I found it at NAPA. It can be added to the gas or poured/sprayed into the carburetor. Johnson Outboard recommends cleaning out carbon annually on my 112 SPL. There is also a product called Sea Foam Deep Creep. It is the same product in aerosol. Since I couldn't find Deep Creep, I used a clean spray bottle filled with Sea Foam to spray in the carburetors. It seemed to work pretty good and I could tell an immediate difference in how the engine ran afterwards. I certainly can't give expert advice, but I have used Sea Foam just recently. Hope this helps.<br /><br />----------------------------------------------------<br /><br />www.StriperChaser.com
D
DJ
Guest
Re: Sea Foam ??
rolmops,<br /><br />I've used it for years as a fuel stabilizer for everything from outboards to cars to lawnmowers.<br /><br />Good stuff-IN MY OPINION.
