Re: sea king
Are you sure it is an oil leak.If there is an oil leak usually there will be water present in the gearcase or milky looking lube.Its not unusual for exhaust residue to to drip out.It will have a gassy smell not the gear lube smell.
VWB is usually indicates a Chrysler built motor.Chrysler became Force in 85.
Tank may use a Chrysler connector may be the same for early Force motors.It may be available right here at Iboats.
