Sea Ray 135 V6 Intermittent "bogging"
hawktuner
Hey guys, the forum is great, I've learned alot already. I've read alot of other posts, but none seems to fit my situation exactly.<br /><br />I'm having a problem with an 89 Searay (Mariner?) 135 HP V6. Just bought it, ran great. After a couple of trips, all of the sudden, it just didn't have any holeshot, (wouldn't pull me up on a slalom ski, with only 2 men in the boat) and would only pull about 4500 rpm WOT.<br /><br />Took it to reputable outboard guy, who said it was probably bad gas. Compression is approx. 135 on all holes. I filled it full of 92 and it ran like a champ on the next outing. With 1000 lbs of people and a full gas tank, it yanked me right out of the water on a slalom ski, (I'm about 225 lbs).<br /><br />So, I carefully filled the tank full on the way home from the lake, thinking I must've taken on water condensation from not having the tank full before. Next trip out, the same problem showed up, it would barely pull me up on two skis. I have to admit, there is a noticable smell of gas, so it could be loading up or something. But I guess I just figured that would "clean up" after running at the "crippled" WOT rpm of 4500 rpm for a few minutes. Plugs all seemed reasonable.<br />Battery is at about 12.58V when engine is off, and 13.5 V when the engine is at 2000 rpm.<br />Inductive timing light indicates "fire" to each plug wire, (assuming that I'm not getting erroneous "crossover" from a nearby plug wire that would falsely trigger the timing light's input).<br /><br />I've read alot of posts from this forum that indicate many possible sources of this problem: bad gas, water in gas, stuck float, bad fuel pump diaphram, bad coil, bad power pack(s), bias of power packs not equal, stator, voltage regulator, and rectifier. I guess I'm overwhelmed and wondered if there was a most likely candidate considering the year and model of this motor?<br /><br />Any help is greatly appreciated,<br /><br />Thanks,
hawktuner
Re: Sea Ray 135 V6 Intermittent "bogging"
JB,<br /><br />You are right. I must've accidentally <br />selected the forum below the "mercury & mariner outboard" forum. I will post again on the <br />correct forum.<br /><br />About the motor, as far as I can tell, <br />it is a 1989 Mercury/Mariner 135 HP,<br />original equip. on a 19ft. Sea Ray, 19P prop,<br />motor #C213481<br /><br />Thanks for your help.
hawktuner
Moved this post to the Mercury Forum<br />Thanks
