Sea Ray Rayder F14 (1995) Drain Plug
shesails
Hi. can someone assist please. I have a 1995 Searay Rayder F14 Jet Boat, i need to replace the drain plugs (can someone tell me the SIZE i need and WHERE I can order from). thanks in advance.
shesails
since the boat is older, i don't normally find what i need in the store. Are you saying the plugs are standard and those on the store shelves should fit?
jbcurt00
Every boat I've had but 1, which drained thru below the hull, used the plug I posted in the transom mounted drain tube, from an early 1950s, thru several 60s & 70s, and my small 12ft open 1983 Sylvan fishing utility.
Highly likely to fit yours if they have transom mounted drain tubes.
GA_Boater
Welcome aboard.
Some parts are standards, like drain plugs. Same ones have been used and have available forever.
You may have trouble finding some motor and pump parts that are No Longer Available (NLA) from the manufacturer, but the aftermarket makes some parts.
The chances of finding an Owners Manual for a 25 year old boat is remote. You would be better off getting a manual for the motor and pump.
