What is the bottom drain below the motor that the check valve goes into with the hose called?!
L Lldavis12 Recruit Joined Jun 19, 2020 Messages 1 Jun 19, 2020 #1 What is the bottom drain below the motor that the check valve goes into with the hose called?!
