Sea Ryder sportjet90 NEW owner ....PROJECT RESURRECTION
ChevyBrit
Hi Guys new to the forum, new to Boats but not new to engines 2 strokes and anything mechanical... I picked up a Sea Ryder sea raider i think with a sportjet90
and before i try to fire it up i wanted to go over some basics ive learnt here like the compression test.. connect a water hose clean the carbs flush the tank check for a spark etc etc .. one thing im looking for is a manual .. a thread suggested they're on here but i cant find a link ... can someone point a newb in the right direction ??
Cheers
ChevyBrit
Found a manual, found the dealer hose to run water through the engine while testing out of the water and completed a compression test too...
ChevyBrit
hoping my documenting this will be of help to someone else ...
ChevyBrit
Found the hose to connect my water supply to, on this boat its on the starboard side toward the rear of the motor ....
I'll have a look around for a fitting to connect up ....
None of your photos show up
The searaider with a sport jet 90 is not a stellar performer. They make a bunch of noise, however are a bit slow
ChevyBrit
I also pulled the plugs and was happy to see a pretty good colour ... on a 2 stroke it'll tell you a lot. A nice biscuit colour on the centre electrode shielding is a good indication that it was running fine when it was last pulled out of the water.
