sea sense fuel water filter with clear bowl
Crosbyman
never had water in the clear bowl...but how often should the filter be changed
( I run my 75 etec about 40 hours per year , use evindure fuel treatment 2+4D carbon guard and sea foam regularly in my fuel
Chris1956
Gee, I would think you can get several years out of a filter, as you do not run too much fuel thru it. I will guess maybe 120Gal/year. Watch for rusting of the filter case. Change it before it rusts thru....
Crosbyman
thanks.. I burn maybe 30 gal in al/year l with mostly trolling to medium rpm
