Sea water pressure sensor
metsfan3197843
I’ve gone through 2 sensors in 3 seasons. Can anyone convince me it’s a bad idea to just dummy the sensor out? I keep up with impeller changes and watch the temp gauge. This thing has been more of a nuisance than protection. Both sensors were OEM and not cheap. At the very least I’m going with a cheap sensor this time can’t be any worse...
Thanks
alldodge
I wouldn't even try to convince you not to dummy it out, they have been a PITA ever since Merc started using them
If you can figure out how to dummy it, I would like to know how
I have an older motor but have installed a mechanical gauge to keep an eye on the pressure
metsfan3197843
Thanks guys. Have a bud who tore apart the sensor, installed the correct resistor and heat shrank the assembly and plugged it back in. I’m probably gonna do the same and install a mechanical gauge as suggested in the off season, which in Alaska isn’t far away
metsfan3197843
On the mechanical gauge what scale are we looking at? I’m thinking 0-25 PSI?
alldodge
What resistor value?
Mine is 0-40 and have seen 26 psi. Started looking for 0-30 but did not find one, and now glad I didn't find it, because being in the middle range for normal use would give the gauge an easier time.
When first throttle up I see 25 or so and after running around 4K rpms for a while it will go as low as 18.
metsfan3197843
I’ll ask him about the resistor and thanks for the pressure info. Much appreciated
achris
More fish than mountain goat
As the seawater pump pressure sensor is a 3 wire sensor, there's likely 2 resistors. If I was to has at a guess, I'd use a couple of 10K, set as a voltage divider...
...........................|10k...........|10k
5v (Gry wire) ----/\/\/\/\/--------\/\/\/\/\----- 0v (Blk/Pnk wire)
.....................................signal (DkBlu/Wht wire)
Chris.....
(Best I can do using just text...)
