76SeaRay
- Aug 24, 2017
- 1,071
Now for issues with Sea Water Pump fit. I rebuilt the pump with new seals and impeller and bench tested. Works great so decided to go ahead and install it. When I did, I found that I only had 1/4 inch of adjustment range. Swinging it to the outside, the top of the bracket hits the timing cover and the end of the adjustment slot. I think that is normal however at that point I only have 1/4 inch clearance to the edge of the damper.
Investigation showed that the new damper is an 8 inch damper but that one is called out for the 7.4L engine. The damper should be 6 3/4 inches for the 5.7L. So, taking the damper back to the machine shop on Monday. Once I removed the damper, I can only get 1/2 inch adjustment due to the plug on the Sea Water pump hitting the side of the oil pan (won't know about damper clearance until I get the replacement). In this orientation, I can put in 4 pump to bracket bolts and the hoses line up great. I can rotate the pump about 180 degrees to put the plug on the outside but then I can install only 3 pump to bracket mounting bolts and the pump outlet port doesn't line up very well with the pump to oil cooler crossover hose. Either way the pump pulley to the crank pulley is also very close.
Anyone using this pump that can tell me more about the adjustment range and if the mounting looks correct? Note that the top bolt for the bracket to engine sits in an odd spot relative to the slotted hole. Thanks..
