Sea water pump
tomasz
Hello everyone,
Is the sea water pump something you replace every season?? I noticed on the diagram that there is a impeller part #
862232A 2. Was wondering if after 5 seasons and 198 hours its time for it to be replaced? Also is it a hard DYI?
Serial No: 0W666094
Don S
Re: Sea water pump
The Alpha I Gen II drives should get at least 3 to 5 years out of the impeller. We used to change customers impellers after 3 in salt water just as preventive maintenance.
The whole pump seldom fails.
tomasz
Re: Sea water pump
Hello Don,
Thank you for your quick response to my question however I'm not sure we talk about the same thing. If you have a chance, check out this link.
https://webapps.brunswick.com/literature/literaturePartsInfo.do
Never mind Don,
I just realized that that diagram is for bravos.
Don S
Re: Sea water pump
Your serial number doesn't tell us what raw water pump your using, and impeller part numbers don't help unless you can remember all the different part numbers. I can't
Impellers for the pump shown in your picture above shouldn't be used more than 2 years. Anything over that is luck.
