Re: Seadoo 717 Rebuild Crankshaft.
try this guy joe 727-488-5353 he probably has some good used cranks or he can do yours but honestly it is a lot of work and pretty complicated to rebuild a crank yourself and by the time you buy all the seals and bearings it would be better to do an exchange for a rebuilt with s b t
also if you wore out the brass drive gear for the rotary valve,, you need to be sure you are oiling it,, some people remove the oil injection and don't think about it oiling the rotary valve drive gear,,
