Seafoam inside truck in carpet
redneck joe
My gallon jug sprung a leak. I'm blotting best i can. other ideas? About 2 qts
Pull carpet and pad, lay on driveway, liberally work in dawn dish soap. Let sit for an hour
Liberally rinse with garden hose
Repeat
Then use laundry detergent, liberally work in. Rinse, let dry in sun for a few hours.
Then reinstall
Oil gone, carpet cleaned
redneck joe
Yeah scott i got a buddy that owns a body shop if it gets pulled new will go back in. Going to try to cean with my small carpet cleaner
You can try it in place, however the pad will require you to soak an area abou 5x the size of the carpet stain
Still need to use dawn dish soap then laundry detergent
bruceb58
If you didn't use snake oil, this would never have happened! :)
southkogs
Bummer ... I was kinda' hoping the sea foam would have made the inside of the truck smell like a Gulf Coast Beach. :pout:
GA_Boater
Redneck Joe has no carbon build up in his truck! And no skeeters in the neighborhood. :D
Good ya got it gone, Joe. :smile:
