Seafoam?
timmathis
Where do you buy it? How much does it cost? And or Is there any thing that You can get at Audozone or Advance auto. That is good to help clean out your fuel system? Thanks, Tim
JB
Re: Seafoam?
Outboard Non-repair topic.
roscoe
Re: Seafoam?
$3.49 to $5.99 for a 16 ounce can, depending on where you buy it.
2cycle
Re: Seafoam?
Tim,<br /><br />You can also get it at NAPA here in the upstate. Sometimes Advance will carry only the liquid pour can and not the Deep Creep that can be sprayed in the carburetors. It seems to vary from store to store in my experience.
Marauderk
Re: Seafoam?
Napa and advanced have it here in florida. It's good stuff amazing difference in my 73 50 hp after i ran a can thru it
timmathis
Re: Seafoam?
The spray, Do you use it when the carbs are still on or is it for when you take them apart for cleaning?
2cycle
Re: Seafoam?
Originally posted by Tim Mathis:<br /> The spray, Do you use it when the carbs are still on or is it for when you take them apart for cleaning?
You can spray the Deep Creep into the carbs while running to the point of loading up the cylinders. Then you turn the motor off for about 15 minutes and then restart at high idle to burn everything off. Refer to the FAQ section below - I'm pretty sure there is a much more detailed description of the process. Just be prepared for a lot of smoke and residue.<br /><br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=36;t=000006
FishyFun
Re: Seafoam?
Deep Creep and Sea Foam are oustanding products and have worked very well on my 82 Honda BF100.<br /><br />lee
