Seal part number - Alpha 1
Rick Stephens
Hi all. Need the right part number - the exploded parts diagram shows 2 seals. Location - output shaft on the upper gear box. The lowest seal that is right in front of the water pocket. I was replacing a half melted pocket and noticed a piece of the seal spring hanging in there. Diagrams appear to show 2 different seals at that location: 26-96503 and 26-32511.
Noticed on achris's video that it is recommended leave the o-ring off that shaft. That's probably what gutted the seal out.
Now I also get to weld a nut to one of the water pocket cap screws. Broke off removing it. At least 3/16 or so is sticking up, so get to run a nut down on it and weld the center. Fun - not sure I ever had to weld on a 1/4 inch nut before. Pretty small. Wish me luck.
Thanks for confirmation! Stern drive serial listed below.
Bt Doctur
Re: Seal part number - Alpha 1
yep, there are 2 different seals there.one seals the oil #11 in the upper unit and the other seals water out of the shaft area. 11 is replaced after you disassemble the upper.10 can be changed without disassembly
Rick Stephens
Awesome. Thanks!
Rick
