Sealant for water fittings on exhaust??
Darin Jordan
What sealant does one use on the water fittings for the water fittings on the exhaust manifolds, and also for the water fittings on the Center Risers/Elbows?
Thanks,
Bt Doctur
Re: Sealant for water fittings on exhaust??
Permatex #2, Permatex Aviation Sealant.,plumbers pipe dope stick
Darin Jordan
Yep....I use the Permatex thread sealant...
No teflon tape..;)
OK, just so I'm clear... iBoats.com sells a Permatex #2 Sealant... but it doesn't say anything about aviation or threads...
http://www.iboats.com/Form_A_Gasket...6140096--**********.731605008--view_id.135126
Permatex makes a #3 Sealant that DOES say aviation and also mentions sealing hoses... http://www.permatex.com/products/Au...tex_Aviation_Form-A-Gasket_No_3_Sealant_a.htm
Will either work?
Bt Doctur
Either one is fine
gadget73
i get the Permatex #2 at the local Napa, but I've also used standard plumber's pipe dope without issue.
Permatex #2 is a seperate product from aviation sealant, which is a seperate product from thread sealant. Its kinda similar stuff, and will do the job just fine tho.
